making bridge pins http://www-.luthiersforum.com/forum/viewtopic.php?f=10101&t=19026 |
Author: | mikemcnerney [ Thu Oct 02, 2008 10:32 am ] |
Post subject: | making bridge pins |
I would like to make my own bridge pins. Is there a tool out there to cut the taper, or plans on how to build one? How critical is the degree of taper, I have a set of taper pin reamers already, or do I have to buy some kind of 'standard' one? Mike McNerney, ottawa |
Author: | Hibdon Hardwood [ Thu Oct 02, 2008 10:59 am ] |
Post subject: | Re: making bridge pins |
Mike, Take a look at Louis' 'Turning Pins' tutorial here: viewtopic.php?f=10117&t=17905 You may also contact him about his bridge pins too. Good Luck, Andrew |
Author: | Louis Freilicher [ Thu Oct 02, 2008 11:36 am ] |
I did an updated tutorial on making pins with a small metal lathe. http://www.luthiersforum.com/forum/viewtopic.php?f=10102&t=15015&hilit=new+turning+pins The usual tapers are 3 deg or 5 deg. I make my bridge pins with a 3 deg taper and my end pins 5 deg taper. I'd be happy to help you figure out a set up if you have any questions. Louis |
Author: | mikemcnerney [ Thu Oct 02, 2008 12:14 pm ] |
thanks Louis & Andrew, WOw, there certainly a lot of different ways to do things. Not having done work on a metal lathe I haven't thought it through the way you approach it, but I see it works well. I am thinking about making something like a pencil sharpener & maybe even mounting it in the headstock of my wood lathe. Either way cutting the shank (taper) first. As you have done I would work with stock long enough for 2 pins. After the tapers are cut I would band saw into 2 pieces. I would then put the shank into a homemade chuck either wood or aluminum with the coresponding taper & turn the rest either with a designated profile tool such as yours or freehand, & I can sand the head at the same time . If I do get it together I will let you know> Mike |
Author: | joel Thompson [ Thu Oct 02, 2008 3:41 pm ] |
Thats a graet tute louis, do you think you could do this with a small wood turning lathe. It looks like a mini metal working lathe would be better if you are seriouse about knocking a few hundred pins, Joel. |
